Posty bez odpowiedzi |oraz Aktywne tematy Dzisiaj jest 2025-11-03, 10:09x
Udostępnienie zdarzeń kontrolki .NET w AmBasic
Post Udostępnienie zdarzeń kontrolki .NET w AmBasic
Mam problem z udostępnieniem zdarzenia kontrolki .NET w AmBasicu. Poniżej kod kontrolki C#:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Drawing;
using System.Data;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.Runtime.InteropServices;
using System.Reflection;
using Microsoft.Win32;
using System.Threading;
namespace ActiveXSourcing
    [ComVisible(true)]
    public delegate void ClickEventHandler(int x, int y);
    [GuidAttribute("0422D916-C11A-474e-947D-45A107038D12")]
    [InterfaceTypeAttribute(ComInterfaceType.InterfaceIsIDispatch)]
    [ComVisible(true)]
    public interface ControlEvents
        [ComVisible(true)]
        [DispIdAttribute(0x60020000)]
        void ClickEvent(int x, int y);
    [ProgId("ActiveXSourcing.MyWindowControl")]
    [ClassInterface(ClassInterfaceType.AutoDual), ComSourceInterfaces(typeof(ControlEvents))]
    [Guid("7C21F7A3-6CFE-4E7B-AA2C-AEC09D4C39D5")]
    [ComVisible(true)]
    public class MyWindowControl : System.Windows.Forms.UserControl
        System.Windows.Forms.TextBox tx = new TextBox();
        private void InitializeComponent()
            this.Name = "MyWindowControl";
        event ActiveXSourcing.ClickEventHandler ClickEvent;
        public MyWindowControl()
            : base()
            initMyWindowControl();
        private void initMyWindowControl()
            Size = new System.Drawing.Size(300, 50);
            tx.Text = "Click on the TextBox to invoke  'ClickEvent'";
            tx.Size = this.Size;
            tx.Click += new System.EventHandler(ClickHandler);
            this.Controls.Add(tx);
        [ComVisible(true)]
        private void ClickHandler(object sender, System.EventArgs e)
            if (ClickEvent != null)
                ClickEvent(0, 0);
A tak to wygląda w AmBasicu:
dispatch ct1
int id1
int Sub ct1_ClickEvent(int a,int b)
   message "Klik"
endsub
Int Sub OnCommand(int id, int msg)
   If id == id1 Then
   endif
EndSub
form "Test",600,300
   control "ActiveXSourcing.MyWindowControl", ct1,10,10,500,200
   id1 = button "ok",25,250,50,20,1
int ext = execform OnCommand
error ""
Kontrolka jest widoczna w formie ale nie reaguje na kliknięcie. Co może być przyczyną?
2016-07-07, 17:10
Post Re: Udostępnienie zdarzeń kontrolki .NET w AmBasic
Iście szatański pomysł! Też bym chciał, choćby do obsługi grida. Ale nie umiem. Pewnie pan Zbyszek z Sage już o tym myślał, ale czy wcieli w życie...
Zdaje się, że eventy z grida nie wrzucają nic do OnCommand, ale możesz się jeszcze upewnić. Może coś się zmieniło. Na pewno próbuj na najnowszej wersji.
Przyczyna? To nie jest obsługiwane. Ambasic to nie VBA. W VBA w Erpie na pewno obsłużysz.
2016-07-11, 22:03
Jarek75 pisze:
Zdarzenia obiektu MxGrid są jak najbardziej obsługiwane -> viewtopic.php?p=25630#p25630
Jarek75 pisze:
Nie wcieli bo już w Sage nie pracuje
Jarek75 pisze:
Zdarzenia obiektów nie są w OnCommand tylko w osobnych Sub'ach
2016-07-11, 22:55
Fajnie, dobrze wiedzieć. Zostałem trochę w tyle. Może zatem trzeba zmienić parametry suba w ambasicu na (dispatch par).
2016-07-11, 23:33
lucyfer pisze:
Mam problem z udostępnieniem zdarzenia kontrolki .NET w AmBasicu. Poniżej kod kontrolki C#:[...]
Użyłeś UserControl jako obiektu eksportowanego do COM.
Jego właściwości i zdarzenia są widoczne w AmBasic.
Wystarczy
int Sub ct1_Click()
   message "Klik"
endsub
2016-07-12, 09:14
Wystarczy
int Sub ct1_Click()
   message "Klik"
endsub
Niestety to nie działa :-( Po kliknięciu w kontrolkę żadnego komunikatu.
2016-09-13, 12:52
możliwe, że trzeba wystawić zdarzenia na zewnątrz przez
        public event EventHandler ControlkaClick
            add { this.Click += value; }
            remove { this.Click -= value; }
2016-09-13, 13:41
Panowie udało się z tego zrobić działającą kontrolkę z obsługą zdarzeń w Ambasic czy nie? Jeśli tak to podzielicie się kodem kontrolki i Ambasic? Dzięki.
2016-11-04, 01:01
Na tym forum nie ma nowych nieprzeczytanych postów. Kontrolki .NET w formatkach AMBASIC Handel > 2015
Kartomiotacz
2016-12-30, 20:59
Na tym forum nie ma nowych nieprzeczytanych postów. Załączniki wlasne kontrolki w AmBasic
sebapr
2009-04-15, 12:58
sebapr Wyświetl najnowszy post
Na tym forum nie ma nowych nieprzeczytanych postów. Integracja AMBasic z COM i .Net
tborawski
2015-09-09, 11:26
Na tym forum nie ma nowych nieprzeczytanych postów. Drukarka fiskalna w sieci LAN - UDOSTĘPNIENIE
cieniucieniu
2013-01-29, 11:44
Użytkownicy przeglądający to forum: AdsBot [Google] i 3 gości
